Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
DRPHIL914 |
Nov 23 2019, 02:34 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Looks nice , did you put the spring retainer clip at the top space?
tvdinnerbythepool |
Nov 23 2019, 03:13 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
@mepstein I was thinking the same thing! (IMG:style_emoticons/default/confused24.gif)
tvdinnerbythepool |
Nov 23 2019, 03:14 PM
@DRPHIL914 Hi! Not sure what that means...can you clarify?
DRPHIL914 |
Nov 23 2019, 04:47 PM
There are 6 I think slots for the retainer that holds the spring retainer clip. It looks like you are set at the very top one ( grooves on the yellow billestien shock) it ma be a bit too springy and high at that setting, at least that was my experience. Mine is at the third slot down, seems about right for height and feel, but every car is different |
tvdinnerbythepool |
Nov 23 2019, 05:06 PM
@DRPHIL914 gotcha! Thanks for clarifying. Yes It's at the top spot.
I'm having to kind of do a reset on the car. I bought it about 18 months ago and i'm trying to under the fuckerage and get it back to stock-ish. It has been "Modified" by the last guy who did a piss poor job on everything. Missing alignment shims to the wrong ECU, everything has been done wrong on this car. I'm totally open to pulling the springs out and changing notches. The more pressing issue with the lower ride height is the Rivieras (I believe, correct me if i'm wrong) have tires too large for my car and their offset 195/60/R15. With the saggy old springs there was about a piece of paper clearance between the tire and the fender (That includes the fact that the PO rolled the Fender Lip to try and make clearance). Any guidance on tire size for these? I'd like to buy Fuchs at some point and have been contacted, but this thing is like a money pit at the moment, lol! (I'm sure it always will be) |
Nov 23 2019, 05:44 PM
914-6 GT in waiting Group: Members Posts: 19,635 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
@DRPHIL914 gotcha! Thanks for clarifying. Yes It's at the top spot. I'm having to kind of do a reset on the car. I bought it about 18 months ago and i'm trying to under the fuckerage and get it back to stock-ish. It has been "Modified" by the last guy who did a piss poor job on everything. Missing alignment shims to the wrong ECU, everything has been done wrong on this car. I'm totally open to pulling the springs out and changing notches. The more pressing issue with the lower ride height is the Rivieras (I believe, correct me if i'm wrong) have tires too large for my car and their offset 195/60/R15. With the saggy old springs there was about a piece of paper clearance between the tire and the fender (That includes the fact that the PO rolled the Fender Lip to try and make clearance). Any guidance on tire size for these? I'd like to buy Fuchs at some point and have been contacted, but this thing is like a money pit at the moment, lol! (I'm sure it always will be) I put my springs on a lower notch but the car was so low I had to raise it up. I would start where you are, let the car settle a bit and then reassess. Too high is better than too low. It's hard to go wide with Rivs. They just have the wrong offset. I have 195x65x15 on a stock narrowbody with 5.5' 2.0 Fuchs, fit is great. 205x60x15 on 6" cookies. Fit is very good. Neither car has rolled fenders. Starting with the right wheel is important. |
DRPHIL914 |
Nov 23 2019, 07:16 PM
Looking at the tyre size charts for comparison my
205/55-16 diameter is 24.9” your 195/60-15 diameter is 24.2” looks like 195/65-15 would be perfect, you are about 3/4” smaller than stock. Also they offset of time is an issue, I have lots of room with 205/55-16 on 6” wide rims so you can get the correct 15”x5.5” rims (2.0 Fuchs) and you can do 205 wide , some guys have been able to do 215’s but this varies from car to car. Don’t go crazy it doesn’t help much at all for street driving to go so wide. Remember a 205/55-16 is 8” wide on a 6” rim, 195/60 15 is almost 7” wide on a 5.5” rim, so plenty of tread contact on the ground. |
tvdinnerbythepool |
Nov 23 2019, 08:35 PM
Any one else have Rivieras that can weigh in?
@drphil914 I'm thinking I could go down to 185 or even 175. These 195s are FAT and just look too wide aaaaaand they don't really fit. More of the last guys "mods" (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/WTF.gif) I also noticed some tire rub inside the front wheel well... |
DRPHIL914 |
Nov 24 2019, 06:35 AM
Any one else have Rivieras that can weigh in? @drphil914 I'm thinking I could go down to 185 or even 175. These 195s are FAT and just look too wide aaaaaand they don't really fit. More of the last guys "mods" (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/WTF.gif) I also noticed some tire rub inside the front wheel well... I have not had the Rivieras but my car had the EMPI VW rims on it with similar issues when I bought it , even rubbed with 185’s. I do like the Pedrini and Mahle best but the 4-lug Fuchs are nice, too, all have proper spacing to better fit a 914. I had a set of thr Mahle but ended up doing the 5-lug conversion and going with Fuchs. You can find some on World Classifieds I am sure. |
Nov 24 2019, 12:24 PM
So I think what Porsche calls the link bearing (#5) that holds the end of the shaft in place is acting as a washer on the shaft. There is a normal washer on the end for the inner suspension console. Attached image(s) |
jmitro |
Nov 24 2019, 02:29 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
There are 6 I think slots for the retainer that holds the spring retainer clip. It looks like you are set at the very top one ( grooves on the yellow billestien shock) it ma be a bit too springy and high at that setting, at least that was my experience. Mine is at the third slot down, seems about right for height and feel, but every car is different it also will depend on the spring rate and unloaded length of the spring. I have 140lb Weltmeisters (don't know the unloaded length) and the spring perch is on 4th notch from the bottom |
tvdinnerbythepool |
Dec 1 2019, 10:43 AM
Holy cow! That was stressful! Not sure how in the world this got done before Ian's video. Either way, one side done. Will do the otherside tomorrow. (IMG:style_emoticons/default/aktion035.gif) |
tvdinnerbythepool |
Dec 2 2019, 09:40 PM
tvdinnerbythepool |
Dec 2 2019, 09:43 PM
And while I'm asking...Torsion Bars!
L for Driver R for passenger But....which way do they go in? Does the L/R point to the headlights or the driver? Thanks!! |
iankarr |
Dec 2 2019, 09:58 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,525 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Holy cow! That was stressful! Not sure how in the world this got done before Ian's video. Either way, one side done. Will do the otherside tomorrow. (IMG:style_emoticons/default/aktion035.gif) Ha! You shoulda seen the outtakes (IMG:style_emoticons/default/wink.gif) Looks like you did great. Congrats! |
Dec 2 2019, 10:15 PM
Stupid question for the night. Bilsteins going up front. Does this little rubber gasket go on between the strut and the top cover as like a bumper? or does it go on after the cover is on between the strut cover and the car? The little rubber gasket gets tossed. It's just there for shipping. Unlike Boge, there is no bumper under the cylindrical dust cover. Bilsteins have an internal bumper. Also, no oil in the strut housing like older strut inserts. All my info comes direct from Bilstein. |
tvdinnerbythepool |
Dec 3 2019, 08:10 AM
bbrock |
Dec 3 2019, 08:55 AM
And while I'm asking...Torsion Bars! L for Driver R for passenger But....which way do they go in? Does the L/R point to the headlights or the driver? Thanks!! Turns out it doesn't really matter. The twist on the bar is in the same direction no matter which end you install to the front. Swapping left and right is a different story. |
tvdinnerbythepool |
Dec 18 2019, 10:34 PM
Lo-Fi Version | Time is now: 17th December 2024 - 12:47 AM |
