| bdstone914 |
Nov 7 2019, 01:04 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,391 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
3 pair Rear shock bolts $40 a set
Rear Hubs $75 a set 1 set left Steering U joints $40 a set Push-rod rod tubes $40 a set w/o O rings, $60 with Viton o rings Tow hook $50 Sold but have more - Spare tire hold down plate and bolt $25 Shipping by USPS flat rate small $8, Medium duty $16. Attached thumbnail(s) |
| Tdskip |
Nov 7 2019, 01:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Tasty!
| Luke M |
Nov 7 2019, 02:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,604 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Hi Bruce,
I'll take a set of the steering u-joints. Pm me the pay pal info. Thanks, |
| mepstein |
Nov 7 2019, 02:16 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,919 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Bruce - I'll take a set of steering U joints. Thanks, Mark
| aharder |
Nov 7 2019, 03:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,095 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region
Bruce,
I'll take a set up the Steering Joints and the Spare Hold Down. I have your paypal, will those fit it a small? Thanks. Allen |
| bdstone914 |
Nov 7 2019, 06:17 PM
@aharder date='Nov 7 2019, 03:23 PM' post='2760163']
Bruce, I'll take a set up the Steering Joints and the Spare Hold Down. I have your paypal, will those fit it a small? Thanks. Allen [/quote] Yes they will fit in a small flat rate box. Do not send friends and family. It removes your address and removes the shipping disciunt from paypal. |
| DRPHIL914 |
Nov 8 2019, 08:12 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
bruce I will take a set of U-joints and a set of the rear shock bolts!
Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! |
| bdstone914 |
Nov 8 2019, 10:12 AM
@DRPHIL914 date='Nov 8 2019, 08:12 AM' post='2760364']
bruce I will take a set of U-joints and a set of the rear shock bolts! Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! [/quote] Let me get a count on thr u joints. I think you will be getting the last pair. Not clear on what added hardware you need. I think you are referring to the bumper shock hole cover plates. I just found them there. Not sure what size hardware is needed. Bruce |
| DRPHIL914 |
Nov 8 2019, 02:08 PM
not I was referring to the bolts that hold the front shock tower in place 4 of them , and the nut that holds the top concave washer on the top of the front strut , and that large concave washer too.
-let me know on the steering u- joint. if yhou are out I can wait until another run of them just put me on the top of the list, it may be a while before I do the steering rebuild and get into that, but right now I would like to do the rest of the hardware on the struts . Phil [quote name='bdstone914' date='Nov 8 2019, 11:12 AM' post='2760397'] @DRPHIL914 date='Nov 8 2019, 08:12 AM' post='2760364'] bruce I will take a set of U-joints and a set of the rear shock bolts! Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! [/quote] Let me get a count on thr u joints. I think you will be getting the last pair. Not clear on what added hardware you need. I think you are referring to the bumper shock hole cover plates. I just found them there. Not sure what size hardware is needed. Bruce [/quote] |
| bdstone914 |
Nov 8 2019, 03:04 PM
@DRPHIL914' date='Nov 8 2019, 02:08 PM' post='2760458']
not I was referring to the bolts that hold the front shock tower in place 4 of them , and the nut that holds the top concave washer on the top of the front strut , and that large concave washer too. -let me know on the steering u- joint. if yhou are out I can wait until another run of them just put me on the top of the list, it may be a while before I do the steering rebuild and get into that, but right now I would like to do the rest of the hardware on the struts . Phil [quote name='bdstone914' date='Nov 8 2019, 11:12 AM' post='2760397'] @DRPHIL914 date='Nov 8 2019, 08:12 AM' post='2760364'] bruce I will take a set of U-joints and a set of the rear shock bolts! Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! [/quote] Let me get a count on thr u joints. I think you will be getting the last pair. Not clear on what added hardware you need. I think you are referring to the bumper shock hole cover plates. I just found them there. Not sure what size hardware is needed. Bruce [/quote] [/quote] Ok, i know what you need now. I do have a pair of u joints for you. Pretty sure i have the strut cup washers too. Bruce |
| mepstein |
Nov 8 2019, 03:40 PM
Bruce - I just sent payment. Thanks mark
Lo-Fi Version | Time is now: 26th September 2026 - 09:56 AM |
