| R Dub |
Nov 7 2019, 07:41 PM
Member ![]() ![]() Group: Members Posts: 126 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
My driver's side visor will not stay up. It always falls in the down position. Passenger one is fine. Any idea how to fix this?
| DickSteinkamp |
Nov 7 2019, 07:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
| FlacaProductions |
Nov 7 2019, 08:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,278 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
If those are tight, make sure the pins are firmly seated in the mounts. Those pins shouldn't spin. They should be stationary and the visor pivots on them. If they spin, take the whole visor off along with the mounts, separate it all and insert the pins in the mounts. Give them a light tap with a hammer and/or apply a little glue and then reinstall in the car as a unit.
| R Dub |
Nov 8 2019, 08:27 AM
I'll check it out. Thanks for the input
Lo-Fi Version | Time is now: 27th September 2026 - 11:14 AM |
