> 914World Classifieds Rules
5 Pages V « < 2 3 4 5 >
> FS: Bronze Side-shift console bushing - NEW!, * Featured Item *
JuniorVarsity
post Jan 14 2024, 06:24 PM
Post #61
Does anyone know of a source for brass bushings for the shifter rod as it passes through the firewall and then into the coupler box at the tranny (side shift)? I'm pretty unimpressed with the plastic replacements from 914rubber and pelican. I hadn't yet thought about the bushing under the shifter in the cockpit; was focused first on all the play in the rod as it traverses the firewall and side shift box.....
914werke
post Jan 14 2024, 07:57 PM
Post #62
Not sure I am understanding which bush(s) you are after?
The one offered in this thread replaces the castellated nylon one in the "shift console".
914werke
post Jan 31 2024, 12:01 PM
Post #63
914werke
post Feb 28 2024, 12:55 PM
Post #64
(IMG:style_emoticons/default/aktion035.gif)
914werke
post Mar 5 2024, 02:01 PM
Post #65
914werke
post Mar 5 2024, 02:03 PM
Post #66
914werke
post Apr 3 2024, 11:37 AM
Post #67
(IMG:style_emoticons/default/rolleyes.gif)
914werke
post Apr 17 2024, 12:35 PM
Post #68
QUOTE(JuniorVarsity @ Jan 14 2024, 05:24 PM) *
@JuniorVarsity did you get your Q answered?
TMM914
post Apr 17 2024, 06:51 PM
Post #69
Order placed….thank you for making these available.
914werke
post Apr 22 2024, 10:08 AM
Post #70
914werke
post May 8 2024, 09:49 AM
Post #71
Back to the top ... (IMG:style_emoticons/default/evilgrin.gif)
914werke
post May 24 2024, 12:30 PM
Post #72
technicalninja
post May 24 2024, 06:52 PM
Post #73
I've got a tip no one has mentioned.
That puppy is a "sintered" bushing, and they all say "self lubricated".
The Datsun Z uses one of these bushings as the pilot bushing for the clutch.
If you put one in "as made" it will die quickly. The lubricant that is in the bushing is not enough...
The way to better lubricate the bushing is as follows:
Place bushing on thumb and fill the interior of the bushing with the oil of your choice.
Fill it completely full and then with your other thumb over the other end of the bushing create hydraulic pressure. Don't press hard as I have split one showing this trick to another tech.
With mild pressure you will see the oil "weep" through the bushing. The sides of the bushing will go wet!
It looks like "special effects" when you do it.
Now the bushing is properly lubricated...
Probably won't matter much in this application but in a pilot bearing application it's a requirement.
This bushing looks great.
I will order one for my car.
Thank you for making these!
914werke
post Jun 4 2024, 01:29 PM
Post #74
914werke
post Jul 11 2024, 12:49 PM
Post #75
(IMG:style_emoticons/default/w00t.gif)
914werke
post Aug 7 2024, 12:51 PM
Post #76
914werke
post Aug 30 2024, 10:13 PM
Post #77
https://www.youtube.com/watch?v=uQaKqs0gNZw
(IMG:style_emoticons/default/happy11.gif)
914werke
post Sep 8 2024, 06:18 PM
Post #78
914werke
post Oct 29 2024, 12:46 PM
Post #79
914werke
post Nov 5 2024, 04:36 PM
Post #80
In stock (IMG:style_emoticons/default/aktion035.gif)
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 1st April 2025 - 01:32 PM
