| ptravnic |
Jan 6 2020, 10:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None
My 73 orange 914 was recently restored by Brad Mayeur in Peoria, IL (I'm located in Chicago) where the only thing that wasn't replaced/reconditioned was the 2056cc engine that I rebuilt myself. I've come to terms with the fact that I'm a terrible engine rebuilder (IMG:style_emoticons/default/post-2-1117899824.gif) and have a couple of busted pistons and an expensive paperweight now on my hands. Hence, I will be procuring a replacement. Something like what Jake/McMark collaborated on years ago would likely do the trick.
Who's got lines on a 2056 (or maybe even a 2270) that can be as close to plug and play as possible? Note, Brad will be doing the swapping but I'm looking to source a suitable replacement engine. Thanks in advance! -pt |
| JOEPROPER |
Jan 6 2020, 11:19 AM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,209 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
there was a Raby engine for sale here a few days ago. From Oregon I think...
@9144me2enjoy I think that was the seller, but may not be spelled correctly. |
| ptravnic |
Jan 6 2020, 11:45 AM
there was a Raby engine for sale here a few days ago. From Oregon I think... @9144me2enjoy I think that was the seller, but may not be spelled correctly. Thanks - that seller PM'd me a few mins ago. Much appreciated! -pt |
| ptravnic |
Feb 5 2020, 07:02 PM
still in the market for the elusive replacement engine... |
| gman3850 |
Feb 5 2020, 07:42 PM
Newbie ![]() Group: Members Posts: 9 Joined: 23-February 16 From: gilbert az Member No.: 19,699 Region Association: None |
https://www.thesamba.com/vw/classifieds/det....php?id=2342043
needs to be put together but looks like a decent price |
| 9144me2enjoy |
Feb 6 2020, 10:00 AM
Member ![]() ![]() Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
I saw this engine on CL out of Portland. This is a engine builder. No affiliation. His posted email address is f5d23b7d82333800a7983d925fd84222@sale.craigslist.org
Attached thumbnail(s) |
| Tdskip |
Feb 6 2020, 10:22 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Why not ring one of the builders here or Vince?
| 9144me2enjoy |
Feb 6 2020, 10:31 AM
That would make a whole lot more sense! (IMG:style_emoticons/default/agree.gif)
| Al Meredith |
Feb 6 2020, 05:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 986 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I've built 2056 engines for myself and for others for years and would be happy to do one for you . The freight may not make it practical. When you install a cam it is necessary to perform cam geometry and that is costly. Most of the engines I build come to $5000 +/- Al .
| KevinW |
Feb 6 2020, 05:39 PM
Newbie ![]() Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest
I saw this add on Samba. No affiliation
| JOEPROPER |
Feb 6 2020, 07:45 PM
You're not that far from Original Customs. I'd look him up if I were you.
| ptravnic |
Feb 8 2020, 12:11 PM
| rbzymek |
Feb 8 2020, 08:14 PM
Member ![]() ![]() Group: Members Posts: 203 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest
I would also suggest a SCAT 2056 long block ($3536) like I purchased last year. I requested 8.5 CR, WEB 73 cam, 40x38 valves on which I re-used my L-Jet FI from the old 1.8. I put on over 1000 miles and it runs great. It also sounds good with a Triad muffler. Next up is a larger (50mm) throttle body from a 2.1 Vanagon.
| 913B |
Feb 8 2020, 08:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
I would also suggest a SCAT 2056 long block ($3536) like I purchased last year. I requested 8.5 CR, WEB 73 cam, 40x38 valves on which I re-used my L-Jet FI from the old 1.8. I put on over 1000 miles and it runs great. It also sounds good with a Triad muffler. Next up is a larger (50mm) throttle body from a 2.1 Vanagon. That's a good price. There site says assembled "yes" but sold as a kit? I couldn't find their warranty if any? Any regrets about your purchase. Thanks |
| rbzymek |
Feb 8 2020, 09:52 PM
No, it's an assembled long block, not a kit. The Summit Racing site shows a 2056 SCAT long block kit for about $200 cheaper but I would prefer that someone else perform the work and keep it from leaking. I looked at my invoice and it actually has 42x38 valves. The warranty is one year and no core is requested. I had a major overheat on the 1.8L so the long block route was the best way to get back on the road quickly. I was disappointed that they could not advise whether to vent or plug the heads. (914word reseach: plug to keep oil from collecting in the valve covers)
It runs fine and so far no regrets. |
| IronHillRestorations |
Feb 9 2020, 08:16 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,956 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
My luck with used engines has been hit and miss.
| rbzymek |
Feb 9 2020, 11:44 AM
My luck with used engines has been hit and miss. Perry, Can you elaborate on what you consider a used engine? There are no new cases, only P's & C's, rods and newly cast heads. Not sure about new cranks. Do you mean "used" as in not rebuilt? Regards, Ray |
| Tdskip |
Feb 9 2020, 11:46 AM
I’d assume “used” equals someone else’s engine that has not been fully rebuilt.
| yostcorners |
Feb 13 2020, 09:54 AM
Newbie ![]() Group: Members Posts: 1 Joined: 14-March 19 From: peachtree corners, ga Member No.: 22,957 Region Association: South East States |
| Tdskip |
Feb 13 2020, 09:56 AM
Lo-Fi Version | Time is now: 6th October 2026 - 08:15 PM |
