> New GB - Electrical - Ignition and fuel injection harnesses, Complete plug and play injection harnesses labeled!
Mikey914
post Feb 5 2020, 01:50 AM
The rubber man
We have been doing these for a while now. We want to bring the cost down, and doing these in quantity will allow for us to to reduce the cost and pass that on. We are looking for 10 of each to get the pricing good for you.
1st
The ignition harnesses -
We have the replicated all of the parts including the L shaped tube at the transmission reverse light.
We have the
70-71
72
73-76
We have these for sale on the site but want to gear up to make in bulk and are offering a price for the GB if we can get 10 takers.
These are correct color coded wires and plugs
Just +1 Ignition harness and the year
we need 10 and can provide these for $210 reg 250
25 and we can make for $199
Mikey914
post Feb 5 2020, 02:15 AM
The rubber man
Now for the Fuel Injection harnesses
These will save you hours of tracking down shorts that are intermittent.
We have the
72+ 1.7 L
and the 73 20.L harnesses
we are just finishing up the early 70-71 harness this week
And can do a 1.8 harness if there is an interest
we have reproduced all the parts needed to make these even the D grommet at the ECU.
As well as the circuit board mount clip. Notice the way we wrap the wires so they will not pull. The only part we didn't reproduce is the "handle" that screws into the bracket on the board, as you shouldn't need to replace them. Ours will accept the old handle.
Best of all we label our ends. Is this the #3 or #4? pretty easy to tell. As well as the other ends. We have taken the liberty of creating a common ground for the 3 leads that require it. easy enough to un-clip and go direct if you wish, but we tried to make it as easy as possible.
These normally go for $494 each, but if we can get 30 takers we can sell these at $399 each. I'm hoping more as we may be able to reduce further if we get the economy of scale
Just need a +1 for the F/I harness with engine and if it's 1.7, early or late.
I think you will like these.
https://900designs-container.zoeysite.com/1...-wiring-harness
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
ctc911ctc
post Feb 5 2020, 09:30 AM
Put me down for one of each,
C
jesse7flying
post Feb 5 2020, 10:49 AM
+1 Ignition harness for a '71.
9one4tay
post Feb 5 2020, 06:36 PM
+1 ignition harness for a 74'
914four
post Feb 9 2020, 09:25 AM
73-76
The quality appears to be good from the pictures. If you get enough for the GB I'm in for an ignition harness for a '74.
Kelvin
walterolin
post Feb 9 2020, 11:18 AM
One of each for a 1970 1.7.
Thanks
lvnzdrm
post Feb 9 2020, 01:44 PM
I purchased and installed the FI harness into my 72' it fit like a glove and all connections worked perfectly. Connectivity is awesome and car runs great.
ctc911ctc
post Feb 10 2020, 01:44 PM
QUOTE(lvnzdrm @ Feb 9 2020, 02:44 PM) *
pvollma
post Feb 10 2020, 04:49 PM
+1 on ignition harness for '76
Maury4
post Feb 10 2020, 09:22 PM
I need 1 for '74 1.8
Mikey914
post Feb 10 2020, 09:23 PM
The rubber man
QUOTE(Maury4 @ Feb 10 2020, 07:22 PM) *
Ignition or F/I harness?
Maury4
post Feb 10 2020, 09:24 PM
I need Ign harness for '74 1.8 for 1.
thanks,
Rick
Mikey914
post Feb 11 2020, 12:22 AM
The rubber man
Ignition I have. We are still working on the fuel injection harness now.
Rikyrat
post Feb 12 2020, 03:25 PM
+ 1 ignition Harness 74 1.8
Rick Gould
Chris914n6
post Feb 12 2020, 04:30 PM
Jackstands are my life.
Ignition harness is different between Djet and Ljet.
potomacmidget
post Feb 13 2020, 08:03 PM
I gotta have more cowbell....
+ 1 for ignition for 71
+ 1 for 71 FI harness
Thanks,
Reg
Rob-O
post Feb 13 2020, 08:45 PM
‘74 1.8L FI harness for me.
914Sixer
post Feb 13 2020, 10:27 PM
Best investment you will make for a good running engine. Engine electrical gremlins are a pain.
seanpaulmc
post Feb 17 2020, 11:55 AM
Is there a close date on this GB?
- Lo-Fi Version Time is now: 10th August 2026 - 11:30 AM
