> Ravena green L65K, mix available?
larryM
post Jul 31 2020, 12:56 PM
emoze
posting Q for new member 935DP
Ravena green L65K needs info on formula to mix for repaint NOW
doug_b_928
post Jul 31 2020, 04:03 PM
I don’t have the formula but will need this as well. The local supplier says that sikkens u base (solvent) has the colour. I’m planning to get a color card from them to compare to what’s left of the original paint on my car. But it will be a while before I can get to it. I’ll watch this thread with interest.
914e
post Jul 31 2020, 04:59 PM
PPG should be able to match it. An old formula might not even work anymore, the pigments have changed over the years.
partsman912
post Jul 31 2020, 08:14 PM
This is what I used.Attached Image
partsman912
post Jul 31 2020, 08:15 PM
Turned out perfect . This is single stage ,no clear coat.Attached Image
Blue6
post Jul 31 2020, 09:35 PM
Now that’s a beautiful car. Bump
rgalla9146
post Aug 1 2020, 07:15 AM
Matcing shirt too !
Beautiful.
Tdskip
post Aug 1 2020, 07:23 AM
Just be aware most moderns paints/clear are too bright to fully match.
I am a bit surprised the paint shop can’t look this up.
@partsman912 - nice work!
sixnotfour
post Aug 1 2020, 01:31 PM
Base Paint: Dimension DM628
L65K Ravenna Green:
Code:
DM628 Base Paint 75.77 g
DM529 Clean Yel 70.89 g
DM528 Ferrite 16.63 g
DM504 Yellow G 3.29 g
DM522 Strong W 0.08 g
Sherwin-Williams Automotive.
https://www.thesamba.com/vw/forum/archive/i...-40--index.html
partsman912
post Aug 1 2020, 08:37 PM
Bottom is as nice as the top . This was the first time using Nason (you may remeber them as Dupont) paint .Always used PPG in the past but the local supplier went out of business. I must say it was wonderful to use if you go by the spec sheet directions. Car was down to bare metal used epoxy sealer first then medium build primer before putting down 3 coats of color.
- Lo-Fi Version Time is now: 12th September 2025 - 07:33 PM
