| Unobtanium-inc |
Jan 14 2021, 07:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,487 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None
Me and the kids decided to start playing with Epoxy Resin. Avi made little tea cups, I made Porsches!
Attached thumbnail(s) |
| Mikey914 |
Jan 14 2021, 08:06 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Silicone works much better. It's how we started making parts. Very time consuming but fun.
| Unobtanium-inc |
Jan 14 2021, 08:28 PM
| 73-914 |
Jan 14 2021, 09:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 702 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None
Dow RTV gr8 stuff
| Tdskip |
Jan 14 2021, 10:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Very cool
| jrblackbox |
Jan 15 2021, 10:20 AM
Member ![]() ![]() Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None
| Mikey914 |
Jan 15 2021, 10:27 AM
Undercut on the windshield with top off was to much (IMG:style_emoticons/default/beerchug.gif)
| Unobtanium-inc |
Jan 15 2021, 11:03 AM
Me and the kids decided to start playing with Epoxy Resin. Avi made little tea cups, I made Porsches! What no 914?? Next round, it's so easy I'll be doing a bunch. Attached thumbnail(s) |
| Unobtanium-inc |
Jan 16 2021, 03:06 PM
Ok, so after polishing and clear coating, this is where we are. I'm trying some more refinements, but overall it's fun!
| VaccaRabite |
Jan 17 2021, 04:14 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,906 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
You need to rig up a vacuum chamber or a pressure pot to out gas all those bubbles.
Zach |
| Unobtanium-inc |
Jan 17 2021, 08:25 PM
Tried to do black resin, worked out ok, but I kind of like the clear better. Might experiment with lite tinting, rather than solid colors.
Also, ran out of resin, so ordered 2 gallons, it's gonna be a long winter. Attached thumbnail(s) |
| Spoke |
Jan 17 2021, 08:39 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,424 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Looks good. I like both the clear and the black. I'll take a 930 in clear if you're selling any... (IMG:style_emoticons/default/beerchug.gif)
| Unobtanium-inc |
Jan 19 2021, 08:09 PM
Ok, made a new mold tonight and yes there is a 914 in there!
Hoping to do all these this weekend, check back for updates. Attached thumbnail(s) |
| infraredcalvin |
Jan 20 2021, 08:34 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,764 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
Can you make some ice cube trays out of those? That would be slick!
| flat4guy |
Jan 20 2021, 09:33 PM
Member ![]() ![]() Group: Members Posts: 483 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
Looks like fun - how heavy are they? I wish we had winter in Calif - I was doing yard work in a T shirt today.
| Unobtanium-inc |
Jan 20 2021, 10:46 PM
Looks like fun - how heavy are they? I wish we had winter in Calif - I was doing yard work in a T shirt today. They are lighter then they look. And mold making is harder then I thought, I must have gotten lucky with my first one because I've failed on the last two. Shooting for number 3 this weekend. |
| Unobtanium-inc |
Jan 24 2021, 07:12 PM
So after three tries to make a larger mold for more cars, and three failures I went back to the drawing board. More research showed me an alternative method to making the mold that looked very promising, and a lot less work and mess. It involved DAWN soap and water, pretty simple, right? I tried and it was much easier. I poured resin in the new molds so tomorrow we shall see if the finished result is better. But I now have 11 car molds, so everything from a 917, to a Speedster, to a RSR. One drawback, the new method take all the paint off the little cars in the mold making process. Strange byproduct.
Stay tuned. Attached thumbnail(s) |
| Unobtanium-inc |
Feb 3 2021, 09:25 PM
Ok, so lots of trial and error later, more error actually. I've upgraded the mold making twice and am much happier with the latest results, shiny and crisp, without any buffing or sanding. I'll keep working but the process is improving, and I'm still having fun!
| burton73 |
Feb 3 2021, 11:17 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,079 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
If your mold and material is very cold and the pouring area is cold you can have problems. Pre-warm up the molds and material to a nice 80 or 90 degrees or more and it will help. Also, if you have a vacuum chamber for some reason, mix, and then deair the mix for a couple of minutes and pour slowly in the mold. The very small bubbles will come out in the chamber Part of that combo is used for A/C system but the pot can be a modified 3 paint pot.
You can also use a paint pot and set it up for 30lb PSI. The bubbles will get so small that you will not see them but you have to leave the pressure on for a long time to make sure the plastic is hard. If not hard the bubbles will show. I just put my pressure on the compressor line and leave it overnight and open it up in the AM Been casting this way for 46 years. Bob B 3 Gallon Vacuum Chamber and 3 CFM 1 Stage Pump to Degassing Stainless Steel Set up is like $100. ![]() |
| Unobtanium-inc |
Feb 4 2021, 06:38 AM
If your mold and material is very cold and the pouring area is cold you can have problems. Pre-warm up the molds and material to a nice 80 or 90 degrees or more and it will help. Also, if you have a vacuum chamber for some reason, mix, and then deair the mix for a couple of minutes and pour slowly in the mold. The very small bubbles will come out in the chamber Part of that combo is used for A/C system but the pot can be a modified 3 paint pot. You can also use a paint pot and set it up for 30lb PSI. The bubbles will get so small that you will not see them but you have to leave the pressure on for a long time to make sure the plastic is hard. If not hard the bubbles will show. I just put my pressure on the compressor line and leave it overnight and open it up in the AM Been casting this way for 46 years. Bob B 3 Gallon Vacuum Chamber and 3 CFM 1 Stage Pump to Degassing Stainless Steel Set up is like $100. ![]() Thanks for the tip! |
Lo-Fi Version | Time is now: 9th September 2026 - 01:21 AM |
