Flyinlow |
Flyinlow ![]() ![]() Group: Members Posts: 54 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada ![]() ![]() |
Uncertain if this harness is original to car as rear window defogger switch and lighter side by side but only one set of wires…red / black twined with red/ white and two twined browns TIA Dennisn
Attached thumbnail(s) ![]() |
Ishley |
Member ![]() ![]() Group: Members Posts: 133 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest ![]() ![]() |
I'm pretty sure that is the cig lighter.
Check this diagram... you have to zoom in.... on 59... which is the lighter. http://914world.com/bbs2/index.php?showtopic=331099 You should always state the year of the car.... the wiring diagrams have some differences... I found the right diagram for my year... and i had Kinkos blow them up... print and laminate them so I hae diagrams to refer to. |
Flyinlow |
I'm pretty sure that is the cig lighter. Check this diagram... you have to zoom in.... on 59... which is the lighter. http://914world.com/bbs2/index.php?showtopic=331099 You should always state the year of the car.... the wiring diagrams have some differences... I found the right diagram for my year... and i had Kinkos blow them up... print and laminate them so I hae diagrams to refer to. It’s a 74 2.0 thanks! |
Lo-Fi Version | Time is now: 7th September 2024 - 05:26 PM |
