| slivel |
Aug 3 2026, 01:43 PM
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 551 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Wife and I took the 914 to a cars and coffee (about 20 miles away) yesterday morning. Everything seemed normal except that we started noticing a strange odor on the way home. Just a few blocks from home the engine quit. I managed to get it running, although poorly and got it home. The first thing I checked was the battery. The case was bulging and too hot to handle. It was also outgassing vapor. This is a one-year-old AGM battery.
I got it exchanged for a new one at no cost to me but the experience was unnerving. I suppose that I now have to be certain that my charging system did not contribute to or cause this battery failure. Has anyone experienced this sort of battery failure? It must have been some internal short to have such a rapid decline. I really was concerned that the battery would rupture. The chemical vapors left a coating all over the engine compartment/trunk area. Are there any good ways to neutralize the acid residue? Thanks. |
| NARP74 |
Aug 3 2026, 01:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,533 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
What battery? My experience with batteries over the last few years has not been good. Not the same as yours but I don't get more than three years out of them anymore. Duracell AGM from a shopping club.
| rick 918-S |
Aug 3 2026, 02:25 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,324 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
There is likely a baking soda solution you could buy buy you could also make some up. I would really be concerned about what was left behind. That stuff has killed so many 914's we cant count them all. Your alternator or voltage regulator is likely fried check all the wiring for overheating as well. Maybe the grommets through the rear engine tin is missing causing a short. Glad you stopped.in time to save the car.
| slivel |
Aug 3 2026, 04:07 PM
There is likely a baking soda solution you could buy buy you could also make some up. I would really be concerned about what was left behind. That stuff has killed so many 914's we cant count them all. Your alternator or voltage regulator is likely fried check all the wiring for overheating as well. Maybe the grommets through the rear engine tin is missing causing a short. Glad you stopped.in time to save the car. I made a solution of household ammonia and water and wiped the area down. My thinking is that ammonia is alkaline which should neutralize the acid residue. But maybe my recall of chem is faulty. Way back when I was a kid working at a gas station, the old hands would pour coca cola on corroded battery trays and it worked somehow. Coke contains phosphoric acid, so it is a mystery. I'll checkout the wiring and bulkhead passthrough's for shorts. My battery is actually in the trunk and not in the normal 914 location. Next will be a baking soda wash. Then clean and apply rust reformer and paint. I hope the alternator/VR are OK. My plan is to check the wiring, install the new battery, start it up and check the gauges for abnormalities and the exposed wiring for heat. |
| porschetub |
Aug 3 2026, 04:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,157 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I would suggest that the VR has failed and the battery has overcharged, the OP is lucky the battery didn't blow ,up appears it was close to it .
Not likely the battery was faulty so a full cleanup is required in the enginebay followed by a test to check input voltage @ the battery , don't proceed further if the voltage is over 14.4V (no load) . Don't continue using the car till you have tested otherwise you may have a repeat issue with a possible worse outcome ,good luck and report back, cheers. |
| brant |
Aug 3 2026, 06:11 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,254 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Do you mind sharing the brand of battery?
| GregAmy |
Aug 3 2026, 07:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,696 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Have you measured voltage when running?
| Root_Werks |
Aug 4 2026, 08:34 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,045 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I would suggest that the VR has failed and the battery has overcharged, the OP is lucky the battery didn't blow ,up appears it was close to it . Not likely the battery was faulty so a full cleanup is required in the enginebay followed by a test to check input voltage @ the battery , don't proceed further if the voltage is over 14.4V (no load) . Don't continue using the car till you have tested otherwise you may have a repeat issue with a possible worse outcome ,good luck and report back, cheers. (IMG:style_emoticons/default/agree.gif) Was thinking the same. Odyssey batteries in my Bug and 914 are 7 and 6 years old. Battery in my airplane was 11 years old and finally started to exhibit low voltage. Would think any decent battery would last 6+ years. |
| slivel |
Aug 4 2026, 10:09 AM
| slivel |
Aug 4 2026, 10:10 AM
| bkrantz |
Aug 4 2026, 08:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,760 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Just a bit OT, but lately the only way I get decent life from batteries is to have all my vehicles on maintainer-chargers in the garage. Between older cars that sit for weeks and newer cars that have constant drain from digital stuff, batteries just run down too fast.
| dtmehall |
Aug 4 2026, 08:30 PM
Member ![]() ![]() Group: Members Posts: 349 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
| Root_Werks |
Aug 5 2026, 08:21 AM
Yup, anything that sits for more than a couple weeks is plugged in.
| porschetub |
Aug 5 2026, 01:37 PM
| slivel |
Aug 6 2026, 09:51 AM
Have you measured voltage when running? Not yet, but I will when I finish the cleanup. Good move not an easy task but you will get there ,cheers. Here is an update: The cleanup is finished and I temporarily installed the new battery to see what I've got and begin troubleshooting. My engine is twin plug crank fired and uses Electromotive HPX modules. One of them is inop now and these units are no longer produced. Additionally, my tach is fried so there must have been some voltage spike that took out those devices. Most probably my voltage regulator/alternator caused the problem. I don't know how a battery failing, even with an internal short could generate anything above the design voltage. So now my immediate search is for a functioning Electromotive HPX that I can acquire. And an 8000 RPM tach. If anyone has either of these available, please contact me. Alternately, I will replace the entire ignition system. I want to stay crank-fired and twin plug. What are the options? Last comment/question. Is it possible to pull the alternator on a 914/6 with the engine in the car? I do have an access hole in the firewall. Is there enough room to side the fan module forward to clear the engine shroud and then up and out? |
| eric9144 |
Aug 6 2026, 04:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,798 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California
There's a great old school speedo shop in North Park-- Foreign Speedo, should be able to check/fix the tach (IMG:style_emoticons/default/beerchug.gif)
Foreign Speedo (619) 298-5278 2246 1/2 University Ave San Diego |
Lo-Fi Version | Time is now: 19th August 2026 - 02:41 PM |
