| wonkipop |
Sep 26 2026, 01:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,752 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
interesting 914/6 on BAT at moment.
| 930cabman |
Sep 26 2026, 01:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,860 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
a new high water mark?
with Luc behind this project I'll bet not much was spared (IMG:style_emoticons/default/first.gif) |
| Maltese Falcon |
Sep 26 2026, 05:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,414 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
MSDS exhaust headers installed by RuF on this beauty >>my Sonauto #40 style with our improved merged collectors. Alois ordered 2 sets 1) for this white tribute car, and another set on a tribute car I noticed on Instagram. I'll give him a pass on RuF taking credit for 'Their Stainless Steel exhaust' system...I've met with him and Alois is a totally stand up guy ! The headers are NOT sold in SS, only raw carbon steel/ or Ceramic coated, these in the BaT ad are raw carbon steel.
His BaT writer was probably not aware. (IMG:style_emoticons/default/number40_914.jpg) |
| wonkipop |
Sep 26 2026, 05:24 PM
a new high water mark? with Luc behind this project I'll bet not much was spared (IMG:style_emoticons/default/first.gif) mr car person of the year 2022. no less. i liked his curated photo of the service book. with a couple of original looking sketches lying around underneath. some body kit ideas for a RUF 911? ---------- @Maltese Falcon when only the best will do where else you gunna go? |
| JeffBowlsby |
Sep 26 2026, 06:35 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,366 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
| wonkipop |
Sep 27 2026, 02:01 AM
What kind of rock star would route a wiring harness though the tin w/o a grommet? good eye you have jeff. the answer is a rock star. rock stars are all the same. but .......its also not tin, its fibreglass. probably passable? maybe. grommet probably shatter the edges of the no doubt well and truly aged epoxy assuming its vintage "tins" or is that "plastics" in the case of a "not a not a real porsche" engine. i dunno. (IMG:style_emoticons/default/beerchug.gif) |
| Maltese Falcon |
Sep 27 2026, 03:58 AM
What kind of rock star would route a wiring harness though the tin w/o a grommet? The #40 gt equipped with sheet metal/ no fiberglass here. We did get her with several bumps + grinds appearing on the tin>> but came out perfect after using body shop hammers/ tools then blasted, powder coated. For sure a nice new grommet installed there too. Fiberglass is a nice touch + not necessarily period correct to a gt...but unless it is flame retardant a faulty Weber /fuel line could be a handful. |
| Maltese Falcon |
Sep 27 2026, 04:19 AM
a new high water mark? with Luc behind this project I'll bet not much was spared (IMG:style_emoticons/default/first.gif) mr car person of the year 2022. no less. i liked his curated photo of the service book. with a couple of original looking sketches lying around underneath. some body kit ideas for a RUF 911? ---------- @Maltese Falcon when only the best will do where else you gunna go? I know a guy that like to sketch in Chemestry 2 in school, kept getting sent to 'Study Hall (IMG:style_emoticons/default/biggrin.gif) |
| Maltese Falcon |
Sep 27 2026, 04:25 AM
a new high water mark? with Luc behind this project I'll bet not much was spared (IMG:style_emoticons/default/first.gif) Well they did install Glendale's best. Factory gt headers (re-purposed from 906) only available in 1.5" o/d tubing>> way restrictive on a 2.4L We build these in 1.625" and 1.75" o/d for bigger engines. RuF went with the larger size, and the engine makes just under 250 hp (IMG:style_emoticons/default/welder.gif) |
| mb911 |
Sep 27 2026, 07:45 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,816 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
a new high water mark? with Luc behind this project I'll bet not much was spared (IMG:style_emoticons/default/first.gif) Well they did install Glendale's best. Factory gt headers (re-purposed from 906) only available in 1.5" o/d tubing>> way restrictive on a 2.4L We build these in 1.625" and 1.75" o/d for bigger engines. RuF went with the larger size, and the engine makes just under 250 hp (IMG:style_emoticons/default/welder.gif) I like the positioner as well as the awesome background |
| Steve |
Sep 27 2026, 07:54 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,093 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Nice car and typical build, but to me nothing special or out of the ordinary. Just another GT replica. Curious what the RUF name will bring to the auction. I am surprised.. You would think it would at least have a RUF steering wheel, Seats and some custom body work.
| JmuRiz |
Sep 27 2026, 06:38 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,652 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
They began as a mechanic garage and still to Porsche restorations. The Ruf labeled cars are all them (or previously bodies in white that Ruf builds up with their own VIN).
If I had unlimited budget I’d have them do a factory style restomod (IMG:style_emoticons/default/biggrin.gif) |
| mepstein |
Sep 27 2026, 06:49 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,929 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Nice car and typical build, but to me nothing special or out of the ordinary. Just another GT replica. Curious what the RUF name will bring to the auction. I am surprised.. You would think it would at least have a RUF steering wheel, Seats and some custom body work. (IMG:style_emoticons/default/agree.gif) Cool but nothing that members here haven’t built themselves. |
| Maltese Falcon |
Sep 28 2026, 02:13 AM
Nice car and typical build, but to me nothing special or out of the ordinary. Just another GT replica. Curious what the RUF name will bring to the auction. I am surprised.. You would think it would at least have a RUF steering wheel, Seats and some custom body work. (IMG:style_emoticons/default/agree.gif) Cool but nothing that members here haven’t built themselves. Absolutely Mark, our members here do construct some fantastic machines ! Another 'Perk for these exhaust headers is that their 'Tribute Build went through the TüV inspection, and has passed with an OK (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/marty914.jpg) |
| Shivers |
Sep 28 2026, 04:33 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,650 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Nice car and typical build, but to me nothing special or out of the ordinary. Just another GT replica. Curious what the RUF name will bring to the auction. I am surprised.. You would think it would at least have a RUF steering wheel, Seats and some custom body work. (IMG:style_emoticons/default/agree.gif) Cool but nothing that members here haven’t built themselves. Absolutely Mark, our members here do construct some fantastic machines ! Another 'Perk for these exhaust headers is that their 'Tribute Build went through the TüV inspection, and has passed with an OK (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/marty914.jpg) Nice build, but did it come with a pen holder? (lol) |
| Maltese Falcon |
Sep 28 2026, 08:21 AM
Nice car and typical build, but to me nothing special or out of the ordinary. Just another GT replica. Curious what the RUF name will bring to the auction. I am surprised.. You would think it would at least have a RUF steering wheel, Seats and some custom body work. (IMG:style_emoticons/default/agree.gif) Cool but nothing that members here haven’t built themselves. Absolutely Mark, our members here do construct some fantastic machines ! Another 'Perk for these exhaust headers is that their 'Tribute Build went through the TüV inspection, and has passed with an OK (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/marty914.jpg) Nice build, but did it come with a pen holder? (lol) Adds no Hp/ Tq. but + more Smiles per gallon (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/marty914.jpg) |
| dr914@autoatlanta.com |
Sep 28 2026, 08:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,247 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| davep |
Sep 28 2026, 11:05 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,377 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The VIN stamping on the right inner fender is dodgy. The paint badge is not correct; and what number did they use for the production #? The transmission serial and type numbers certainly look like 911 and not a 914/6.
Other than that, the car build looks good. |
| MCShack |
Sep 28 2026, 12:29 PM
Member ![]() ![]() Group: Members Posts: 81 Joined: 7-March 21 From: Ohio, USA Member No.: 25,305 Region Association: Upper MidWest
The VIN stamping on the right inner fender is dodgy. The paint badge is not correct; and what number did they use for the production #? The transmission serial and type numbers certainly look like 911 and not a 914/6. Other than that, the car build looks good. Agreed, build looks good, looks great really, and I would be damned proud to own it. And yes, there have been several other similar builds here that are/were fantastic as well. The purists out there may not like them so much, but there have been plenty of nice original restoration projects from the members here too, bringing hopeless looking rust piles back to life. (IMG:style_emoticons/default/pray.gif) I was also looking closely at the VIN# and especially the replacement Karmann badge. I was going to ask you what that production # meant. Couldn't read the tranny number well enough to determine what car it came from. I'm not sure how much any of it matters if one is looking to buy a highly modified replica GT tribute clone. (IMG:style_emoticons/default/first.gif) |
| echocanyons |
Sep 28 2026, 03:35 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,119 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
Are the RSR /917 calipers reproductions?
Any other 914s with these? |
Lo-Fi Version | Time is now: 13th October 2026 - 09:20 AM |
